Int wiper switch not working
Old May 2, 2012 | 07:16 PM
84espy's Avatar
84espy
I recently purchased a new delay wiper switch. After installation, it doesn't work. When I turn it to low speed....nothing. When I turn it to high speed, it runs for less than a second and stops. Then I hear the relay ticking. When I turn it back to off, it does one revolution to return to it's stop position. Also, whenI turn it to the off position from the high speed, I can hear the relay working in the low speed (you know..the clicking noise). I know the ground is important for this switch, so I drilled through and made a fresh ground point. If anyone has a suggestion, I would be appreciative. Thanks in advance and here is the switch that I bought:
BWD S3579 - Windshield Wiper Switch | O'Reilly Auto Parts
Old May 2, 2012 | 08:14 PM
VocaTexas's Avatar
VocaTexas
You do have the delay circuitry plugged into the back of the switch, don't you? The switch alone doesn't give you intermittent wipers.
Old May 2, 2012 | 09:21 PM
84espy's Avatar
84espy
OK. Thanks! I thought that the switch would have the relay built in. Off to the j/y since I can't find the part listed.
Old May 2, 2012 | 10:21 PM
OldStyle's Avatar
OldStyle
Rusty Roller
You are looking for something that looks like this; could be red box also. Easy way to tell if the bronco in question, easiest to locate, has delayed wipers is to turn the switch; if it rotates counter-clockwise past stop. Then it is a delay system. Just unplug and you are good to go....
Old May 5, 2012 | 11:14 AM
84espy's Avatar
84espy
Got my relay and now have int wipers. One note for anyone interested in this: if you are going to pull this relay at the j/y from an '80s truck, you will need to remove the dash bezel and then the gauge cluster to get to the one mounting screw for the relay. Thanks for all the help
Boss_358
2009 - 2014 F150
Oct 22, 2018 10:26 AM
Sycostang67
Jan 17, 2010 04:53 AM
Ty_Yota
Apr 17, 2006 06:19 PM
tiap
Electrical Systems/Wiring
Jan 23, 2004 05:40 PM
mustang
Sep 30, 1999 10:47 PM
