Wipers won't "self park"
Old Apr 17, 2006 | 04:42 PM
Ty_Yota's Avatar
Ty_Yota
When I turn off the wipers they stop at whatever point they are at (as if I have turned off the ignition).
What should I look at first? Switch Motor Wiring ???
Thanks
Tyler
Old Apr 17, 2006 | 05:12 PM
Unfairlane62's Avatar
Unfairlane62
Hi does it do it from all wiper speeds or just intermitent, we had the same problem on a machine at work after checking all the wiring and relay it turned out to be a worn switch if it was wiggled about it would work fine, hope this helps
Old Apr 17, 2006 | 05:14 PM
Ty_Yota's Avatar
Ty_Yota
All speeds, & intermitent
Old Apr 17, 2006 | 05:19 PM
Unfairlane62
don't know why i asked about the speeds as this one did it from all speeds too but it had to go through intermitent on the switch to get to the stop position, it was something to do with the switch not letting the power go through long enough to return to park
Old Apr 17, 2006 | 06:19 PM
Franklin2's Avatar
Franklin2
The motor is fed power all the time by a hot wire. Make sure this is ok. This wire supplies power to the motor even if the switch is turned off. There is a cam switch in the motor that opens when the wipers are all the way down in park.
Tyler S
May 21, 2014 11:39 AM
Tyler S
Apr 27, 2014 06:23 PM
Tyler S
31
Feb 27, 2014 03:07 PM
TyCrawf
Feb 14, 2012 08:09 PM
gar
1997 - 2003 F150
Dec 30, 2004 11:20 PM
