I have a 2001 F-250 7.3L crew cab long bed. I purchased it new and it has always been almost impossible to turn the wheel while stopped. Is this normal? If so any recommendations on after-market power steering pumps?
If I rapidly pump the brake while pulling the wheel as hard as I can the way I'm trying to turn will help turn the wheels.
I don't know what it is about the Ford power steering pump... I have researched and found that no one sells an aftermarket high performance pump for the modular engines.
PSC MotorSports.com offers several high performance pumps for Chevy, Suzuki, Toyota, and Jeep. However, they only offer a conversion bracket for the Ford 5.8L and 5.0L engines (see link below).
its just Ford crappy pumps, my dads 2000 diesel does it, my 2004 F350 with 5.4 does it. My buddies 1999 reg cab F250 does it, and my other buddies 2003 F250 with V10 does it. Ive heard that Redhead can drill the inlet nipple slightly bigger thats suppose to help with low speed power? Just havent seen it done yet
had same issue trying to turn 38s.. old pump would struggle and not move em unless I had some momentum, finally broke down replaced both the steering gearing gear boadjusted all I could out of the other for steering slop), and a new pump can turn sitting still no momentum needed..
I had to do a test today as I am from old school and am avoiding turning the wheels without movement.
My PS works just fine at idle with no truck moving. I could sense a bit more restriction, but still could turn the steering wheel with 2 fingers on 2000 model.
Iv got a 99 with 35's. I have to rev the engine up a little when at a stop to turn the wheel. I always thought it was just from the larger tires. I would be interested in a stronger pump when this one dies.
My 2000 V10 F250 did the same thing, could barely turn the wheels unless I revved the engine and moved a little, even then it wasn't perfect but it did work slightly better. Backing up a trailer became extremely difficult, feathering the throttle, moving back and forth just to get the wheels turned into position. I didn't know what the problem was until I changed the ball joints!
I had lived with it that way for a long time, maybe 20k miles or more. I always assumed it was the pump getting weak or gearbox failing. Around 65K I began to notice some slight looseness in the ball joints so I changed them out. I could barely believe it the first time I drove it; it was instantly fixed. I could easily turn the steering wheel back and forth with one finger even with the truck in park, now at 106k it still steers just as easily. If you haven't done the ball joints I would seriously investigate that, they are a very common problem.
Simply jacking the truck up will not reveal the problem, mine steered easy without weight on the front axle, I had tried that a dozen times searching for a solution. I was truly shocked and pleasantly surprised to find new ball joints fixed both problems.
The SDs start out with a disadvantage due to the high scrub radius of the front axle geometry. Adding a divergent hydroboost brake booster really kills the turning ability when motionless and braked. Things get worse with age within the hydraulic system as well as the mechanical aspects of balljoints. Adding wider tires really adds to the scrub forces too.
The pump itself has a pretty common volume and pressure output.
I have new Moog ball joints. Problem remains. I do need to change the fluid out though.
i did moog ball joints in my dads 2000, and flushed the system twice.my 2004 has the 5.4 and i also installed moog ball joints and flushed my system with synthetic fluid,all with no change.And both my buddies trucks are 5.4 and V10 so its no added diesel weight. If what fmtrvt said is true our pump are enough, then the geometry must really be ****ty then!
