E brake releases
Old May 2, 2012 | 01:17 PM
gudone's Avatar
gudone
E brake releases
Hi All,
This is my first post here, sorry if I have a noob question.
We recently got a '74 F-250, partly a toy for me and partly my son's vehicle to drive.
He has told me a couple of times that the e-brake releases without warning. Today it happened when he was outside the truck so he had some fun unlocking the truck and stopping it before it really got rolling.
I reminded him to park the truck in a high gear ... but still, I am wondering if this is a common problem and what the fix may be.
Thanx in advance,
Lorne
Old May 2, 2012 | 03:39 PM
montana_highboy's Avatar
montana_highboy
Maybe a worn pawl and/or a fatigued spring in the e-brakes ratcheting mechanism is allowing the pedal to disengage itself....my e-brake hasn't worked in nearly a decade, i've never actually taken the time to check it out.
Old May 3, 2012 | 03:51 PM
gudone's Avatar
gudone
Thanx montana_highboy ... I think I may opt for your approach ... *o)
Does anyone know if there are schematics or pics of the e brake mechanism kicking around?
Lorne
Old May 3, 2012 | 06:42 PM
meborder's Avatar
meborder
Thanx in advance,
Lorne
park truck in low gear or reverse, not high gear.
mechanical advantage works backwards going the other way.
low gear is the easiest for the engine to turn the wheels, but the hardest for the wheels to turn the engine.
high gear is the hardest for the engine to turn the wheels, but the easiest for the wheels to turn the engine.
that's why when you have to push start your truck, you use 2nd or 3rd ... keeps the engine from stopping the truck when you pop the clutch.
Old May 4, 2012 | 12:59 AM
brian1080's Avatar
brian1080
try taking the whole pedal assy out and giving it a good degreasing/lube. I had one in another truck that the little part that hooks would get gummed up and not do what it's supposed to.
Old May 4, 2012 | 01:32 PM
ChaseTruck754's Avatar
ChaseTruck754
I 2nd what Brian1080 said. If you do get the thing out & the teeth on it are worthless or something I have an assemble here I can let go of cheap.
Old May 4, 2012 | 04:18 PM
gudone's Avatar
gudone
Sounds good everyone. I will try to get at it this weekend.
meborder, you hurt my brain with your point about the gear when in park ... it is sort of counter-intuitive but makes sense to me now.
Cheers - Lorne
fpd7
2015 - 2020 F150
Mar 6, 2018 11:38 AM
My1964ford
Nov 1, 2014 11:37 PM
Boodrow379
Feb 1, 2013 08:40 PM
TXKaiser
16
Mar 21, 2007 04:45 PM
Ultramagdan
1997 - 2003 F150
May 21, 2002 09:04 PM
