02 Ranger won't start
Have an 02 ranger 3.0 that runs good most of the time .Once in a while it won't restart after it's warmed up . It does't die and it only cranks but always starts after cooling off.I've had it in the shop twice without any improvement .There are no codes . So far they have changed the Mass air sensor,spark plugs & wires and fuel presure regulator
Next time it happens you need to determine if you have fuel and or spark......you can pull a wire and put an extra plug in it..ground it and crank the engine etc, you can also buy a spark tester for $10...........you also can spray starter fluid into the throttle body and see if it starts. if it starts we are looking at a fuel issue.
if have a reader check for pending codes
Yea, the trouble is it might be a month before it acts up again. I guess i'm hoping for something pretty commen with these 3.0s. It does have spark and I can hear the fuel pump for a short time when the key is turned on.I'm thinking a sensor or something . It seems like it would log a code but doesn't . Thanks
