2006 6.0 water/ oil temps?????
I just completed a 900 mile round trip towing my 5th wheel camper (I think it is about 14k lbs). Traveled from Mass to Carlisle, PA via Rt 84 to Rt 81, very hilly and heavy truck route.
Truck towed like a bear, however I did see what I think are elevated oil temps. The truck runs about 9 degrees different unloaded around town. When towing the spread is 13 - 15 degrees typical, I saw an occasional 15 - 20 degrees different.
Worst was twice after pulling a loooooong grade 5th gear, torque converter not locked (I think that is what happens when RPM changes but gear doesn't????) 2800 RPM or so at 60 miles an hour. When coasting down the other side I saw a 30 degree difference as the water cooled MUCH quicker than the oil. Oil got back down in a couple minutes....
Am I OK? Do I need an oil cooler? Loved the Scangauge II for monitoring these things.
Thanks!!!!
Thanks!!!!
This sounds to me like your truck is okay for now. The oil temp is a little high, but your pulling a lot of trailer, and a key point to me is that the oil temp drops fast once the hard pull is over. That means you are still getting oil and coolant flow, and heat transfer is taking place as it should.
One thing I would question is when the oil was 30° higher than coolant. That is a rather wide swing in my experience. So I wonder what the actual temps were? Is your coolant thermostat in proper range? I don't normally see 30° swings in either oil or coolant temps. The T-stats are prone to weak springs in this engine, and then they open too early.
