i had issues with my clutch pedal being soft and then i had the clutch froze up after i had it in some deep water... thats where my problem started. i changed the master cylinder before i got the clutch broke free over the weekend and it seemed to be working fine, but after driving about 50 miles my clutch pedal went clear to the floor, obviously no clutch. i tried for an hour (in the middle of the street) to get the thing bled out again with no luck. When i open the bleeder and pump the pedal i dont get any fluid out at all, the resivior is still full though... im really hoping that the internal slave on my transmission isnt bad, i dont want to have to drop the tranny. Any thoughts or tips on this would be wonderful! Thanks Guys
Hate to say it but it sounds like the slave cyl. Replace the crossmember bolts with stainless steel bolts it helps alot next time around I dropped my trans in 15 min
