are there any 96 cc350 leveling kit options
Old 04-30-2012, 10:59 PM
fordman67's Avatar
fordman67
fordman67 is offline
Like the title says...ARE there any good options for leveling my cclwb psd up? It just simply has way too much rake! I have searched and searched and not really found any options I am in love with...OR maybe I am crazy?
Yea,dont answer that last questuion....
or do I just need to give the spring shop a call?
Thnks, Aaron
Old 05-01-2012, 05:46 AM
427 fordman's Avatar
427 fordman
427 fordman is offline
Basically just an add a leaf if your springs and bushings are in good shape.
Old 05-01-2012, 06:18 AM
redman84's Avatar
redman84
redman84 is offline
Add a leaf or swap to an f250 rear block.
Old 05-01-2012, 07:11 AM
fordman67's Avatar
fordman67
So ad a leaf,track bar drop bracket,replace bushings it is...any brand anyone had good luck with
Old 05-01-2012, 07:22 AM
redman84's Avatar
redman84
redman84 is offline
I'm sure we have some sponsers here who could help but you could contact cary at ct performance. He should know for sure.
Old 05-01-2012, 10:56 AM
superduty4x4's Avatar
superduty4x4
superduty4x4 is offline
No need for a drop track bar bracket with an add a leaf. The other option is a reverse shackle kit (RSK) and that comes with a track bar drop bracket.
Old 05-02-2012, 02:20 PM
fordman67's Avatar
fordman67
Believe it or not.stock right now it needs a drop bracket.that thing is at a mad angle already.i will post a pick later
Old 05-02-2012, 11:15 PM
Brown Falcon's Avatar
Brown Falcon
Brown Falcon is offline
3" RSK from SKY Manufacturing... $350 and a better ride than stock.
Old 05-03-2012, 09:40 AM
fordman67's Avatar
fordman67
Since im dumb...that requires 99and up super duty springs?
Old 05-03-2012, 09:45 AM
superduty4x4
No, you can get an RSK that works with stock springs.
Old 05-03-2012, 10:08 AM
fordman67's Avatar
fordman67
It will ride better because of the rsk or only if used with super duty springs.the only reason i ask is because my wife will be o. Board if i can make it ride any better....u fellas know how that goes ....i dont care other than it leveled up but...
Old 05-03-2012, 10:42 AM
superduty4x4
Most guys say that an RSK even using stock springs rides smoother than the OEM setup.
Old 05-03-2012, 10:54 AM
redman84's Avatar
redman84
redman84 is offline
I've heard that as well but really if your springs are worn out at all then grab you some super duty V codes and you'll have the best possible rife from and OBS truck with OBS axles.
Old 05-03-2012, 10:57 AM
Brown Falcon
I'm using stock springs and it rides well, doesn't ride any worse than it did when it was a 2wd with coil springs...
Old 05-03-2012, 02:14 PM
fordman67's Avatar
fordman67
well,guys I have 2.5" lower in front than rear.I am of the opinion the springs are not too bad shape.Anyone have a spec to go from to tell for sure
Quick Reply: are there any 96 cc350 leveling kit options
