diesel tachometer
Old May 3, 2012 | 05:46 PM
tecgod13's Avatar
tecgod13
Originally Posted by turtlemann14
couldn't you through a tone ring on the crankshaft pully and pick up from there with a hall sensor?
Yeah that could work. The factory one has a sensor that counts the teeth on the IP gear. You'd just have to make sure the setup you use will get the right RPM conversion from the signal that comes out of the sensor (depends what its mounted on and how many ticks per revolution).
big ole ford
Jul 19, 2016 07:01 PM
tlk50
Sep 25, 2009 11:46 PM
JStoddard1
Oct 23, 2008 07:17 PM
Blueovals&Blacksmoke
Sep 16, 2008 05:25 PM
unobvs
May 4, 2007 07:17 PM
