AC Compressor not working
Old Apr 30, 2012 | 03:36 PM
nyaristo's Avatar
nyaristo
Hey guys I got a 04 V10 6.8L excursion with now all of a sudden the clutch won't engage in the compressor. Is there a shut off switch I don't know about or do I have to replace the whole compressor
Let me get your opinions
Thanks
Tony
Old Apr 30, 2012 | 03:58 PM
Sunline Fan's Avatar
Sunline Fan
Excursion Fleet Manager
Tony, there's a repair/mod on here somewhere that involves reducing the gap of the clutch. It seems that from wear, the gap gets wider, so there's a small washer in there that you can replace with a thinner one to reduce the gap down to near factory spec. Then it should engage/better. Some have had very good luck with it, but I personally haven't. It got a little better, but it didn't fix it completely.
The mod is the same, as far as I know, for gas and diesel. The 6.8 compressor/clutch is in the lower front corner of the engine. I believe the sticker showing the belt pattern should show which one it is of the group.
Old Apr 30, 2012 | 05:17 PM
Stewart_H's Avatar
Stewart_H
SpringerPop in the 7.3L forum is the resident guru.
SpringerPop's Compressor Clutch Air Gap
I'll give him a heads up and see if he can add anything.
Stewart
Old Apr 30, 2012 | 05:26 PM
nyaristo's Avatar
nyaristo
Thanks guys I did see the gap I'll look into the write up
Old Apr 30, 2012 | 05:56 PM
nyaristo's Avatar
nyaristo
Seems like that write up was for diesel do you think the 6.8's would have the same problem because the compressor is @ the bottom and looks diff. From diesel well it appears diff. From looking underneath the car but I am going to try it out tho
Old Apr 30, 2012 | 06:45 PM
labman1014's Avatar
labman1014
Doubt u have the same problem I had but worth looking at, my belt came apart and took out the wire connector to the compressor. It sits right over the belt. Just something to look at.
Old Apr 30, 2012 | 07:22 PM
nyaristo's Avatar
nyaristo
Thanks I'll check but my belts fairly new
Old Apr 30, 2012 | 10:42 PM
SpringerPop's Avatar
SpringerPop
The compressor is the same on all SuperDutys. It's an FS-10. Different number of belt grooves on the pulley, is all. Though the clutch plate might be a slightly different design, with rubber isolators, it adjusts exactly the same.
I found that the clutch is much easier to do on the V-8s and V10s if the degas bottle is removed, and that means draining some coolant first.
But it's all do-able, and shouldn't take much more than a couple of hours.
How many miles are on this rig? The air gap usually doesn't begin to be a problem until about 100,000.
Pop
Old Apr 30, 2012 | 10:56 PM
nyaristo's Avatar
nyaristo
I have 170k on mine but I'm guessing tighting up the bolt won't do the work then, it sounds like I'm going to have to tackle it over the weekend
Old May 1, 2012 | 01:53 AM
Monsta's Avatar
Monsta
Sit. Stay.
I think you should first check the simple things. Air gap wasn't my first thought.
Do you have refrigerant? Maybe a rock put a hole in the condenser and all your R134a came out. Hence, no compressor engagement.
Is there power going TO the compressor? Have you pulled the plug and tested for voltage at the connection?
If not, check fuses? Relays?
Old May 28, 2012 | 12:02 AM
nyaristo's Avatar
nyaristo
Found a video on this hope it helps anyone else with this issue
Check out this video on YouTube:
Powerstroke A/C Repair Part 1 - YouTube
Old May 28, 2012 | 12:18 AM
Monsta's Avatar
Monsta
Sit. Stay.
So what was wrong with yours?
the beast 1
Jun 1, 2023 11:43 PM
chdairy7
1997 - 2003 F150
Aug 6, 2011 05:55 PM
gofast51004
Nov 24, 2009 07:56 PM
Mike's 77
Jun 28, 2008 08:21 PM
ncvote
Apr 24, 2005 02:59 PM
