2002 7.3 skipping
Old Apr 29, 2012 | 09:21 AM
MICHAEL34's Avatar
MICHAEL34
2002 7.3 skipping
Hi Guy's I do not know what more I can do,this is the first truck I have had that I did not want something else and I can't fix it. It is skipping, I have replaced the folowing , CPS, FPR, Injectors, glow plugs, valve cover gaskets, rebuilt the fuel bowl, new lift pump, in tank mod, high pressure oil pump and it is still skipping . The check engine light comes on and off since I have replaced the injectors, I have ohmed everthing out and it is good, what am I missing?
Old Apr 29, 2012 | 09:37 AM
mueckster's Avatar
mueckster
What codes are you getting?
Old Apr 29, 2012 | 09:43 AM
MICHAEL34's Avatar
MICHAEL34
I do not have a code reader
Old Apr 29, 2012 | 09:48 AM
mueckster's Avatar
mueckster
I would get the codes read and see what direction that points you. Report back and we'll go from there.
Old Apr 29, 2012 | 10:59 AM
PaysonPSD's Avatar
PaysonPSD
FTE Remembers
New VC gaskets is on the list. Did you replace the UVC harness as well? If not look for a burned center pin on the connector. It is the common ground for the injectors. If you have codes read and get a P1316 take a real good look. See this LINK.
Old Apr 29, 2012 | 05:42 PM
guitarpicr's Avatar
guitarpicr
Might try a known good cps, if u havent already.- May have gotten a bad one- It happens
Old Apr 29, 2012 | 06:06 PM
MICHAEL34's Avatar
MICHAEL34
Thank you bot, I did replace UVC harness as well, and the cps sensor I got from NAPA it was grey, I think that is the good one right?
Old Apr 29, 2012 | 08:09 PM
guitarpicr's Avatar
guitarpicr
Not sure on that - I would try a oem & stay away from the napa cps - Heard of problems that others have had on here with them- Its probably easier to get a oem one & try it b4 you proceed & get to spending too much on other parts -Keep us informed & good luck.
Old Apr 29, 2012 | 08:36 PM
PaysonPSD's Avatar
PaysonPSD
FTE Remembers
Try a DU-87 CPS from Ford. It is sold for the 1994-1997 but works just fine in the 1999-2003.
Here is some CPS testing done by Ken (woodnthings), one of our FTE members.
LINK
Outdoorgirl_72
Jun 13, 2018 07:27 AM
Rving7.3
May 3, 2018 04:04 PM
berta7.3
Jul 30, 2017 11:26 AM
gscoggin3
Sep 12, 2015 03:25 PM
Hawk180
Apr 11, 2012 10:30 AM
