7.3 Ran great to dinner, Ran like poop afterwards
I've got a 2002 F550 with the 7.3, awesome truck but having a little problem...
We pull a fifth wheel RV about once a week with it, but we went out to eat a few days ago and it was running great. When we got back in the truck after dinner, started it up, and it ran like ****. Very shaky and low RPM idle, lack of power getting up any kind of hill. Ended up making it home very slowly, now its sitting in the driveway, will start but almost instantly bogs down and shuts off. Any idea on whats causing this and how to fix??
I already changed fuel filter, replaced map sensor, and checked resistance on each pin in the UVCH(Under the valve cover harness). All injectors to the common read 2.8-3.5 ohms, all the glow plugs read around .5 ohms.
A neighbor came over with his scanner and it did not pick up any codes but the Service engine light is on now.
Any help is much appreciated. Thanks, Tim
Sweet looking setup
Since the SES light is on there are codes. Get a wireless ob2 dongle and the ForScan app will read the codes on our motor. Not all ob2 code readers will work on ours since they aren't completely ob2 compliant. If you use Android devices get one that uses blue tooth, if you use Apple you'll need a WiFi one
Kentpeg
05-26-2014 12:30 AM
Jesser02EX
15
09-13-2013 01:51 PM
watersurgeon
12-11-2007 09:50 PM
Beachbum4143
09-26-2004 03:31 PM
