Question on fuel system
Old Apr 23, 2010 | 11:15 AM
Charlie Bravo's Avatar
Charlie Bravo
This is for an 86 F-250 with two gas tanks. Due to old age, the lines and tanks have developed leaks. The switch valve works when it feels like it. I am going to weld up my own custom tank. I'm going to need a tap on the bottom to go to the fuel pump. The line from the fuel pump back to the tank can be run into the top of the tank. Am I correct. The fuel pump has three ports, two from the gas tank and one to the carb. Best, CB
Old Apr 23, 2010 | 12:08 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Fuel/Gas tanks should not have fittings on the bottom ...
-Enjoy
fh : )_~
Old Apr 23, 2010 | 12:20 PM
Archion's Avatar
Archion
Veteran: Marine Corps
If you did it with rear facing outlets like a Fuel cell, ok, but DO NOT put fittings out the bottom.
Edit, also best to use solid connections, like a fuel cell, AN or equivalent, don't use hose nipples and clamps.
