Subwoffer Box
Old Apr 27, 2012 | 09:05 PM
Regulator1988's Avatar
Regulator1988
Subwoffer Box
Im looking for a pro box for my 4 door something that will use 2 12"
Old Apr 28, 2012 | 10:49 AM
f250rangerexplorer's Avatar
f250rangerexplorer
Heres the one ive been looking at. http://caraudiofactory.com/20042007-...26a3064e18f055 Looks to be pretty nice and can hold 2-12" Subs
Old Apr 28, 2012 | 11:45 AM
Dlinzy's Avatar
Dlinzy
I got this version in 10's fit perfect and my JL's sound awesome.
FORD F250 F350 04-09 DUAL 12" SUB BOX CAR ENCLOSURE | eBay
shipped fast and quite affordable.
D
Old Apr 28, 2012 | 01:13 PM
BLADE35's Avatar
BLADE35
Originally Posted by f250rangerexplorer
Heres the one ive been looking at. 2004-2007 Ford F250-350 Super Duty Pro-Poly Sub Box - Car Audio Looks to be pretty nice and can hold 2-12" Subs
This Box is alot like how mine is
except figure it Cut Down the Middle into 2 separate Boxes
I have 2 12s bhind the rear seat in my truck I also unbolted the seat from the 2 Rails that hold it and slid forward a Touch and rebolted seat
Also keep in mind here a Box that is just made to Fit a 12 inch mayNOT putout as much bass as a box that been designed right and is ported to pull the Bass out.
A 10 inch sub in the right Box will outpreform a 12 inch sub in the wrong Box theres a Fine line here and with the small space in our trucks Its hard to find a good Box vs one that fits. The space is so limited that you almost just stuck with a Box that fits.
What Im getting at is a Box that designed right MAY have a Harder hit than say one that made to Fit a Bigger speaker
In either of those pictures of speaker boxs and even my OWN BOX there are NO ports that I saw. I know I should have a DEEPER HARDER HIT with my 2 12inch subs but its hard to find a Box that Fits that designed right with ports and all that good stuff
Start Looking into a DC Power Alternator too CUZ the OEM alternator is going to FAIL Fast might even want to consider a coil. My DC Power 190amp alt seems to keep right up with it. But I couldnt get a OEM rebuild alternator to even go 5K it started poping the battery light at 13months just OUT of Warrenty. so save some money cant go wrong with DC Power and get the wire upgrade too or you can make your own wire upgrade to
Old Apr 28, 2012 | 01:25 PM
Regulator1988
What's wrong with the alt?
Old Apr 28, 2012 | 01:45 PM
Regulator1988
http://www.sonicelectronix.com/item_...%5BIgnore%5D=1
Air space 1cubic
Old Apr 28, 2012 | 01:46 PM
BLADE35's Avatar
BLADE35
It can BARLEY keep up with the stock truck
A coil may help
I have 2 Amps going a 1000 watt and another 600 watt with 1-0 power wire it went a 5 years or 20K with OEM
But the OEM rebuild didnt last long at all less than 5K and 13months maybe it failed premature IDK I honestly think the AMPS drove it into the ground
Old Apr 28, 2012 | 01:52 PM
BLADE35's Avatar
BLADE35
Thats cool it did recomend a sealed enclosure looks like your headed in right direction that sub woofer looks difffrent than anything I have ever seen B4 might just be the ticket.
Its a Big world out there in stereo stuff just reading this link brings back memorys
I did always want a Fosgate AAmp but them are pretty spendy
Are you planing on a Mono AMP??
Iv just been bridging my amps in MONO
I think a Fosgate MONO Amp would be the best Iv never been able to spend that kinda money on it
Old Apr 28, 2012 | 02:43 PM
Regulator1988
http://www.sonicelectronix.com/item_23548_Hifonics-Brutus-BRZ1200.1D.html?SearchClickout%5Bquery_id%5D=91314 05&SearchClickout%5BIgnore%5D=1
Old Apr 28, 2012 | 02:45 PM
Regulator1988
You replace your deck yet? And what year is your truck?
Old Apr 28, 2012 | 02:54 PM
BLADE35's Avatar
BLADE35
Yes replaced DECK with Pioneer I had to get a Deck with a Remote Turn on for the amps.
It was way easy to change the deck in these I just got the wire pigtails that plugged into factory Harness and then plugged to new deck. NO wire splice at all only splice was the remote turn on Blue wire the rest just plugged in. Oh and a Faceplate Kit with a nice little cubbey hole under deck
Trucks an 03
Old Apr 28, 2012 | 02:55 PM
Dlinzy's Avatar
Dlinzy
A few years ago i built boxes for competition, one of the tricks to getting harder hitting bass is stuff the cabinet loosely with pillow poly fill.
It can completely change the way the woofers respond and is cheap to try at any holly hobby shop or even wally world.
Stuffing the interior of my Sub box. [Archive] - Club Polk
d
Old Apr 28, 2012 | 02:56 PM
Regulator1988
So to get the deck out what do you have to do? Anything with the dash?
Old Apr 28, 2012 | 03:00 PM
BLADE35's Avatar
BLADE35
Never heard this brand amp before the RMS power looked good though
usually them amps have high watts and low rms power but this one look good on RMS Power
Let us know how it all works out
Old Apr 28, 2012 | 03:23 PM
Regulator1988
d
How much of it?
