need quick help with timing
Old Apr 27, 2012 | 02:46 PM
bengerman's Avatar
bengerman
my timing is off, i think.
i'm trying to diagnose a no-start, and i was told that if the rotor was pointing to #1 at tdc the timing should be close enough to start. turned to 0 deg and it was way off, rotated 360 deg, and it's only slightly off (between 1 and 3)
so i'm pretty sure it's off.
here are my 2 big questions:
first, is there a way to tell TDC other than the finger in the sparkplug hole method? i have big hands and by the time i get a finger to the spark plug hole i cant tell the pain from the contortion from pressure from compression
second, my chilton say for base timing to refer to the sticker under the hood, but i can't find any stickers other than the belt routing sticker. does anyone have the proper base timing for this truck?
Old Apr 27, 2012 | 03:02 PM
andym's Avatar
andym
Use a plastic straw instead of your finger to feel the top of the piston. You have to use your finger to feel the air being pushed out of the plug hole though, or you might catch it 180 degrees out.
Once you find TDC, install the distributor so that the rotor points to the #1 terminal. If it still won't catch, try cranking it while you turn the distributor back and forth by hand until it catches.
Old Apr 27, 2012 | 03:06 PM
bengerman's Avatar
bengerman
i did realise i made a stupid assumption, though.
on the crank pulley, i have a little hole and a little pointer. i was assuping the hole was for timing, but i realized it may be the pointer. which is it?
Old Apr 27, 2012 | 03:17 PM
gurueuey's Avatar
gurueuey
If by "hole" you mean the square notch, no, that isn't it. You need to line up with the timing marks on the crank pulley. You should be at 10 deg with the rotor pointing at the #1 piston. On the timing indicator attached to the block, you'll line up 10 deg at the far right side of the indicator. Base timing is 10 deg BTDC.
Old Apr 27, 2012 | 04:19 PM
bengerman's Avatar
bengerman
alright. got that done, got it to kick over, barely, (with the SPOUT disconnected)
shut it down, and it won't start back up.
try again, but with timing light ready in case it works so i can time it properly right away?
and the hole is a little round holefurther towards the passenger side, but i figured out it was the pointer and timeed it from that.
Old Apr 27, 2012 | 07:22 PM
bengerman's Avatar
bengerman
that was the answer. got it to kick over again, timing light in hand, got it timed properly and now it runs like a champ.
smitty7
Jan 29, 2007 10:04 PM
my69ford
Jun 1, 2006 12:10 PM
DT 466Man
16
Oct 2, 2005 08:18 AM
VintageBlueOval
May 5, 2004 10:47 PM
jerrycarl
Jun 17, 2003 09:43 AM
