im tearing my hair out trying to get this truck running again i lost spark had to change the module spark is back now it seem like im not getting enough fuel at the fuel rail the pressure is not as strong as it was before i changed the filter and put another pump in it any ideas what i could try next im not sure maybe a bigger pump might fix the problem
First, don't title your threads "Help" because almost every single thread in here is someone asking for help.
Second, you didn't bother to tell us a single thing about your truck. Year, model, engine, transmission, miles, condition, recent repairs, history, symptoms, etc. You also mention that you suspect fuel pressure is low but didn't post what the fuel pressure is - unless you're just guessing.
91 ford f150 4x4 5.8 i did not runn a pressure test but when u push down on the fuel rail it is not pushing as much gas out as it was before it doesnt seem to have any pressure at all just a small amount of gas dribbles out and repairs that i have done was put a new module on the distributer to gain spark back i also changed the fuel filter and pump in the front tank rear tank has bein removed new lines run to single saddle tank other repairs i have done to the truck had the truck completely stripped put a new cab and box on truck it has bein running since it has bein put back together but i lost the spark and put the new module on after that i had it running but since then i cannot seem to get it to start it trys to start but will not run
