Fuel Problem?
Old May 30, 2009 | 06:23 PM
tralfamadorian's Avatar
tralfamadorian
Fuel Problem?
I have a 1994 F250 with the 300. Sometimes I will start the truck, and it will run badly (like it is running out of gas) and then die. This does not always happen. Also, if i am driving, and come to a stop, then give it gas, it will kind of "cut out" then go fine. It will do this for a while at every stop or slow down, then be fine. The truck idles well and once you get going it drives and runs fine. Fuel Filter maybe?
Old May 30, 2009 | 06:33 PM
rc-or's Avatar
rc-or
hi new hear . Hears just a couple of thoughts sounds like your fuel pump might be going out but first change filter and check fuel pressure at the rail. I have a jeep that does this when its under a half a tank
Old May 30, 2009 | 06:40 PM
jr32560's Avatar
jr32560
I'd start with the filter -then check the fuel pressure at the fuel rail
Old May 30, 2009 | 09:35 PM
tralfamadorian
I figured if it is the fuel pump it would run or it wouldn't. That is how it was on the other two cars that I owned and the fuel pumps went out. I do have the duel tanks, so I suppose that a test would be to run the rear tank and see how that works. The only problem with that is that I never use the rear tank. I bought the truck from a farmer and he never used the rear tank, so I am concerned about sediment in the tank. I don't want to send that stuff through the fuel system. I guess I coulf fill it up and then run it, change the filter a couple times, and call it okay. I don't really want to drop the tank at the moment. But anyhoo, if the filter doesn't help, and then the fuel pressure is low, what would the problems I should look at be?
ten.mile
May 16, 2020 04:34 PM
pbruckne
6.7L Power Stroke Diesel
17
Jan 5, 2020 07:45 AM
jeepfix
Jul 24, 2013 05:56 PM
ten.mile
Dec 11, 2012 05:56 PM
