Headlight Electrical Problem
Old Apr 29, 2012 | 07:23 PM
SnuffthePunkz's Avatar
SnuffthePunkz
Just go HID's, you'll never look back. I did that mod, yes it works but not as much as you would hope for. Went HID's after so happy with them, I installed them on my mothers truck and she loves them no more guess work/sketchy bad weather/night driving issues.
Old Apr 29, 2012 | 07:25 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
here is the running light relay mod.
Adding a Running Lights Relay to a 1991 Ford Truck
Old Apr 29, 2012 | 07:30 PM
'94IDITurbo7.3
are HID's the blue lights?
Old Apr 29, 2012 | 07:33 PM
SnuffthePunkz
Uh, not all blue lights are HID's, and not all HID's are blue. So yes and no.
But generally people go with a blue tint on their HID's (Like me), to cut down on the glare factor the pure white bulbs have. Or they just like the colour.
Warozz has a great writeup around here somewhere with pictures comparing light output comparing them and all his setup.
Running this kit in my 92 F250, and 98 F150, great price (Cheaper than super bright high quality stock bulbs), and they work great.
http://www.ebay.ca/itm/HID-KIT-BI-XE...item3a6a12388b
Old Apr 29, 2012 | 07:39 PM
'94IDITurbo7.3
i did a member search for warroz and did not find any matches.
Old Apr 29, 2012 | 08:19 PM
SnuffthePunkz
That is because I sent that on my cell it decided to "correct" it...
https://www.ford-trucks.com/forums/1...t-upgrade.html
Old Apr 29, 2012 | 08:32 PM
'94IDITurbo7.3
thanks for the link. reading it now.
Old Apr 29, 2012 | 08:50 PM
94 7.3idi's Avatar
94 7.3idi
For that price it's probably cheaped than the realy set up lol thanks for that eBay link
Old Apr 29, 2012 | 08:57 PM
94 7.3idi's Avatar
94 7.3idi
And you have these running in the stock headlight housing correct?
Old Apr 29, 2012 | 09:02 PM
SnuffthePunkz
No problem, it plugs into your existing wiring (Basically the plug you pull out of the back of your existing bulb plugs into the circuit that they have to sense when it needs to be on/high/etc. I'm not sure what was wrong with yours you may have to fix the pre-existing issues that you have first. The short or whatever you showed.
All you have to do when ordering is tell them it's 9007 (Bulb size) for a 1994 F-series pickup, and whatever tint you want. I'm running 6000k I think, just a hint of blue.
Also clean your lenses, it helps. You can go crazy and put the professional cleaners, or get a polishing wheel. I just use tooth paste on a paper towel, little swirls and rinse off. Hell of a lot cheaper and works wonders in a pinch.
EDIT: Stock housing yes. Though you can get Euro/Projections housings and it will aim the light better.
Old Apr 29, 2012 | 09:05 PM
'94IDITurbo7.3
i think i will stick with doing the relays and upgrading to the euro lenses. mine put out nice light at it is now.
Old Apr 29, 2012 | 09:31 PM
SnuffthePunkz
A lot of it depends on where you are as well. It is always overcast, dark, and rainy where I live for like 7 months out of the year, so stock lights in a 20 year old pickup just don't cut it.
Truth be told though the last time I used my HID's not for like lighting up a frozen lake at night (So Canadian I know...) was like 2 winters ago in the middle of a white out blizzard up in the mountains at like midnight, talking High beams, flashers, bumper lights, the works and I could barely see a car length ahead of me. Other than that I've not needed them.
cabloom300
Jan 10, 2014 04:26 AM
western star
May 26, 2013 10:12 AM
mvtofino
Electrical Systems/Wiring
Sep 7, 2005 02:04 PM
a564jim
Aerostar
Jun 30, 2004 07:25 AM
russ88b2
Bronco II
Mar 12, 2004 06:34 PM
