Sponsored by: Innova
Sub-woofer box help sealed vs ported
Old May 8, 2003 | 10:12 AM
ExplorerSp0084's Avatar
ExplorerSp0084
After looking at it today I guess it doesnt realy matter how it will affect the subs mounting because they will be on the bottom in a spot that doesnt need to be covered. But while Im thinking about it is there anything I can use to better the seal between the subs and the uncovered MDF?
Old May 8, 2003 | 08:14 PM
optikal illushun's Avatar
optikal illushun
one sided foam tape works great. i think frost king makes some, just make sure its one sided and foam and u'll be ok.
Old May 11, 2003 | 11:05 PM
ExplorerSp0084
Just an update, Went ahead with the spray on bed liner stuff the Duplicolor from walmart. Looks Awsome the desing on fron trealy looks nice but i may try and color it red or something. Also it took four cans of spray but i did some really thick coats prolly almost 1/4 of an inch.just gotta mount the subs tommorrow, I couldnt find any one sides foam tape is silicone ok?
Old May 12, 2003 | 08:37 PM
smokey6309028's Avatar
smokey6309028
Silicone is what i use on my boxes and it gives a GREAT airtight seal. Only problem is, if you ever decide to take the subs out of the box, they are a little harder to get out.( IE: you might have to pry them lightly out) But besides that, put a nice bead of silicone sealant around the mounting surface, you will be pleased.
Shovelhead 93
2004 - 2008 F150
19
Aug 4, 2010 06:13 PM
walkinghorse
Mar 24, 2009 09:59 PM
bigmandan50
Mar 7, 2007 08:05 PM
JeffreyK
25
Aug 23, 2005 01:00 PM
basshead
Apr 11, 2001 12:24 AM
