Stant Thermostat - Part#
Old Apr 25, 2012 | 07:49 AM
DPDISXR4Ti's Avatar
DPDISXR4Ti
I suspect my new (to me) '91 4.9 has no thermostat. With the temps a bit lower than normal the past few days the engine just isn't warming up - stays all the way to the left in the "Normal" range, and takes a while to get there.
I happen to have a Stant #16308 thermostat hanging on the peg board in the garage, put can't find any application reference for it. It's a rather conventional-looking thermostat but in an older package, so thinking they might have changed part numbers. I can see from the stamping on the flange that it's 54mm. Just wondering if it might work.
Old Apr 25, 2012 | 01:05 PM
882tank's Avatar
882tank
Sounds like your thermostat might have stuck open. Though the Stant is the right size, I wouldn't run it. Head down to the part store and pick up a quality Gates thermostat and gasket. Depending on your climate, I suggest running a 180 degree instead of a 195.
Old Apr 25, 2012 | 06:51 PM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Yes, I figure it's either stuck open or removed entirely. I can see there's a new gasket in there which is why I was guessing it might have been removed entirely by the DPO.
FWIW, the 'stat I have is a 180 degree, and since you've confirmed it's the right size (thanks BTW), I'll probably just run it. I take it you're not fond of Stant thermostats?
Old Apr 25, 2012 | 07:57 PM
882tank's Avatar
882tank
Nope, I'm a Gates guy all the way. The Stant you have should work out just fine though.
Old Apr 29, 2012 | 04:46 PM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Got the housing off yesterday, and sure enough, no stat to be found. I guess that explains pretty well why it wouldn't warm up in cooler weather.
New stat installed. That was an easier fix than most.
Old Apr 29, 2012 | 05:50 PM
882tank's Avatar
882tank
Congrats. Makes you wonder what the hell people are thinking sometimes.
cs2kplus
May 6, 2018 07:15 AM
z 97ford1
1997 - 2003 F150
Sep 24, 2014 05:19 PM
Diabolic
1983 - 2012 Ranger & B-Series
25
Mar 10, 2004 08:51 PM
paulmal
May 5, 2002 06:13 PM
