Power door lock problem, I need some help!!!!
Old Apr 24, 2012 | 11:25 PM
sc-xc's Avatar
sc-xc
The passenger side rear power door lock is not getting power on my 97' F350 crew cab.
I replaced the power door lock bracket that had been broken for the last 5 years, I had just used the ****. Now of corse the door lock is not working, I checked the power lock actuator on a different door and it works perfect.
I checked the plug and it is dead, all the other door locks work properly.
Can anyone tell me where and connections for that part of the wiring harness are located to give me some places to test between for continuity?
Or is there a anything else that could have gone wrong????
Thanks in advance!
Old Apr 25, 2012 | 05:54 AM
BigBlueOx's Avatar
BigBlueOx
There is a plug under the carpet/mat that goes out to the door at the bottom of the "B" pillar on the passengers side. If you don't have power there then I would say that it may be a door lock switch in the master switch in the drivers door, those you could also swap to verify proper operation.
Old Apr 25, 2012 | 06:47 AM
91 Dually's Avatar
91 Dually
Check the wiring that comes into the front of the door itself. Theres a inside the rubber flex boot. They are known to break inside there..
Old Apr 25, 2012 | 09:49 AM
sc-xc's Avatar
sc-xc
Great, I will start there!
The door lock switch in the driver door operates all the other locks, are individual controls for each lock in that switch?
Thanks!
Old Apr 25, 2012 | 11:47 AM
GuitarJesus's Avatar
GuitarJesus
I second checking the wires, just found out my passenger side rear door has the wires cut in half where the door opens. No power to the door lock.
Old Apr 25, 2012 | 12:08 PM
BigJT's Avatar
BigJT
TRY THIS
Old Apr 25, 2012 | 05:20 PM
sc-xc's Avatar
sc-xc
You guys were right on! No sooner do I get in the truck this morning then the lock works perfect and the window in the same door stops!!!
I moved the wiring between the door and the B pillar and they both start working and the fuse blows out.
Looks like I will be opening up the door wire loom and fixing some breaks.
Also thank you for the wire diagram!
Thanks again!
Paddy1998
Jun 6, 2018 08:45 PM
chief1600
Dec 5, 2017 07:57 PM
V8Ranger302
32
Feb 5, 2013 09:52 PM
m thatcher
Bronco II
May 25, 2005 01:10 AM
bronco351
Arizona Chapter
Nov 7, 2002 08:57 PM
