Clutch pedal switch
Old Apr 27, 2012 | 01:46 PM
EffunFiddy's Avatar
EffunFiddy
Thanks for the work you guys are doing on this, I really appreciate it. Bear with me as I'm not very good with wiring at all just yet, but is this switch somehow wired in series with my ignition key wiring? I just know I phrased something wrong there... I'm a newbie to this standard trans stuff but I'm keen to learn
Old Apr 27, 2012 | 02:22 PM
Gary Lewis's Avatar
Gary Lewis
Yes, for an '85 it should be wired in series with the ignition switch. Both would carry the low-current signal to the starter solenoid to cause it to pull in and start the vehicle. But, like the old Christmas tree lights, if one fails nothing happens.
Old Apr 28, 2012 | 04:15 AM
drumfield's Avatar
drumfield
Ok, to qualify this, all this is from my '85 F250.
I did a c6 to zf5 swap, and ran across this.
Under the dash, next to the kick panel, is a 2 wire connector, that with the auto tranny has a jumper installed. On a manual tranny, the jumper is removed, and the connector is plugged into the clutch switch.
You say you have a clutch switch from a truck with cruise, so the switch will have 2 sets of connection plugs. IIRC, one should be normally closed, and one normally open. The normally closed one is for the cruise, and the normally open is for the start circuit.
Just going by memory, it's 4:15 in the morning, so it's dark out, and I can't seem to find my '85 wiring diagram right now. Hope this helps.
Old Apr 28, 2012 | 09:31 AM
EffunFiddy's Avatar
EffunFiddy
Awesome, thanks alot! I found the connecter stuffed in behind the kick panel. Be damned if I can get the thing plugged into the switch. I'll tackle it later when I have a little more patience. Thanks again everyone for your help!
sstouder
13
Mar 2, 2019 07:39 PM
geoffunkel
May 13, 2013 12:19 AM
Bonnie808
Escape & Escape Hybrid
Oct 25, 2010 12:03 AM
oh2bnok
1983 - 2012 Ranger & B-Series
May 4, 2010 01:39 AM
rosett
Aerostar
Jan 9, 2010 06:48 PM
