Clutch Assembly Question
Old Apr 24, 2012 | 07:20 PM
NBC-Steve's Avatar
NBC-Steve
I ordered from Napa Auto Parts a replacement clutch kit and the pressure plate looks very different than what I removed but the holes line up on the flywheel and pressure plate. Any thoughts? Should I worry? I haven't done a clutch replacement yet so this is kinda new...
Old Apr 24, 2012 | 07:56 PM
critterf1's Avatar
critterf1
It'll work just fine.
Old Apr 24, 2012 | 08:00 PM
FineSeventyNine's Avatar
FineSeventyNine
Tennessee Hillbilly
X2......Old one is borg & beck type, new one is diaphragm type.....perfect interchange
Old Apr 24, 2012 | 08:37 PM
nickelndime79's Avatar
nickelndime79
Kind of off the subject but I just put a clutch and flywheel in my truck. That was the easy part. Boy putting that transmission back in was a job. That rascal is heavy!! I was doing it about as easy as possible too. Body is off and setting in the top with a skid loader and my 11 yr old son. Sure helps when the neighbor stops by and gives you another set of hands!
Old Apr 24, 2012 | 08:49 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is on the way!
3x... the diaphram's multiple "fingers" have better and more evenly distributed clamping force. I hope the kit came with an alignment tool.
Old Apr 24, 2012 | 09:55 PM
NBC-Steve's Avatar
NBC-Steve
Yes it did and I think I have an extra one someplace.
Glad to know that this is OK, Now I just need to get the flywheel replaced.
Old Feb 16, 2021 | 09:42 AM
perry xxx's Avatar
perry xxx
Great looking truck, I like it. I had one like that with all the dirt. Went and got some cheap Harbor Fright wet dry sand paper. I think 220 maybe 150 and wet sanded the truck. The dirt came off easy and left this cool old faded paint job with cool patina at least I thought so. The interior will clean up also--- heck you can always do a 100 point restoration if that is what you are looking for, nice foundation.
steve
Old Feb 16, 2021 | 07:34 PM
F-250 restorer's Avatar
F-250 restorer
While the clutch is still out of the truck, confirm that your bolts will be able to be turned once they are put through the holes on the p. plate. I had an issue with that on a new clutch. Good luck.
KKraft
Feb 17, 2020 07:50 PM
dieselsubmariner
Jan 11, 2015 10:39 PM
rustywheel68
Nov 20, 2013 08:06 PM
Tyler S
53
Apr 5, 2012 06:28 PM
mudrunner4ever
Mar 18, 2012 07:26 PM
