What size air compressor
Old Apr 24, 2012 | 03:42 PM
minnesotafisherman's Avatar
minnesotafisherman
What size air compressor should I look into that can run a DA Sander and an Impact wrench, possibly a cheap paint gun, too.
Old Apr 24, 2012 | 09:02 PM
critterf1's Avatar
critterf1
I use a two stage 7hp with a 60 gal tank for my DA.
Old Apr 25, 2012 | 06:57 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
I consider this the bare minimum: Ingersoll Rand® 3 HP 60 Gallon Single Stage Air Compressor - 3496111 | Tractor Supply Company Used one for five years daily, but it never cut off while using.
Old Apr 25, 2012 | 10:11 AM
minnesotafisherman
Cool, thanks guys. That 60 gal isn't too bad pricewise.
Old Apr 25, 2012 | 10:21 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
As usual, if you can afford to go bigger, do so.
Old Apr 29, 2012 | 08:37 PM
cigarxtc's Avatar
cigarxtc
ditto to what the others have said. I use my craftsman 25gallon direct drive compressor for most of my air tools. It can handle the impact wrench, paint gun, and i've pushed it's limits with sandblasting. It can not keep up with da sanders. I had to buy an electric da sander. Go bigger and use a two stage oiled air compressor. You'll be glad you did. I sure wish i did.
Old Apr 29, 2012 | 10:13 PM
minnesotafisherman
Thanks, guys. I think I have come to the conclusion that I am only going to get something that can handle impact wrenches, and maybe a paint gun.
I think I'll just a better electric sander than what I currently have.
Maybe I'll go with a 25 gal like you have, Ron.
Old Apr 29, 2012 | 11:42 PM
fixnair's Avatar
fixnair
Size of the tank is almost meaningless. What you need to do is find out how much air each of your tools use and buy something that delivers as much air @ 90PSIG as the most hungry tool uses.
Your typical 3 peak horsepower cannot keep up with a DA. But you will be able to use it for several minutes before the air pressure runs down to where you can't use it anymore.
I have a 3 peak horsepower Campbell Hausfeld and it does run out of air occasionally but I can always find other stuff to do while it is recovering. I even have a bead blast cabinet that I do small parts in.
STAY AWAY FROM THE OILFREE OR OILESS COMPRESSORS!
Trojan8975
Aug 6, 2011 09:08 PM
reed1951
19
Jan 1, 2008 08:34 AM
200000+F150
Paint & Bodywork
13
Apr 18, 2006 02:01 PM
sancochojoe
Paint & Bodywork
26
Mar 4, 2004 10:15 PM
unioncreek
Paint & Bodywork
Oct 26, 2001 05:01 PM
