coolant filter questions
Old Apr 24, 2012 | 11:27 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Originally Posted by richdawg
So if you overheat where would the coolant go? Would it blow the bottle up or just blow the cap off. I'm sure you have thought about that. It does seem like a good simple place to return it though.
I'm honestly not worried about that, but I think the overflow line will still work as designed. There isn't a ton of water flowing through that line. Maybe I will have to ask Bob about it one of these days, but I'm honestly not worried about it. If I overheat to that point, I have much bigger problems anyways.
Old Apr 24, 2012 | 11:45 PM
richdawg's Avatar
richdawg
So dose that make it like a closed system and the bottle if full all the time?
Old Apr 25, 2012 | 12:05 AM
strokin'_tatsch
Not even close. I'm feeding the filter from the small port on the side of the WP. That is only taking a small amount of the coolant right before it gets to the t-stat and exits the t-stat to the radiator. So, it's kinda like a bypass filter. Plus, if Bob Riley says running the return to the overflow hose, I'm sure it's fine. I'm not worried in any way about it.
Old Apr 25, 2012 | 12:21 AM
07Wolfie's Avatar
07Wolfie
Originally Posted by BlueMule
The supply comes from the head and it returns to the water pump.
Uh-oh... Maybe I hooked mine up backwards! The hose that connects to the top of the water pump is the return flow?
Old Apr 25, 2012 | 06:33 AM
427 fordman's Avatar
427 fordman
Yep, BlueMule(Rodney) is the one who mentioned to hook it up this way to me, both the feed and return, so sounds like yours is backwards.
Old Apr 25, 2012 | 07:31 AM
DIYMechanic's Avatar
DIYMechanic
Here is a post where this is discussed:
PowerStrokeNation : Ford Powerstroke Diesel Forum - View Single Post - Heater Hose Mod aka AC Mod
Seems less than conclusive to me...
Old Apr 25, 2012 | 08:37 AM
Talyn's Avatar
Talyn
I wouldn't hook it up from the pump like that.
Pretty much makes it a full flow filter.
Depending on your filter head.
Your creating another path for fluid to randomly travel.
Old Apr 25, 2012 | 10:29 AM
07Wolfie's Avatar
07Wolfie
Well, I'll be... I suppose that explains why the used filters have been perfectly clean when I cut them apart... all the junk must have been on the inside of the pleats!
Old Apr 25, 2012 | 11:30 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Rodney,
So in this diagram the red arrows are CORRECT?
file:///G:/Word%202001%20HSJ/VARIOS/POWER%20STROKE%20DIESEL/COOLANT%20FLOW%20(REVERSED).htm
Old Apr 25, 2012 | 11:56 AM
Ford4Life7.3's Avatar
Ford4Life7.3
Fine with it being w full flow, i dont use my heater and i plan on changing it regularly so it will never get clogged enough to stop flow. Im just so damned confused now lol! So it should be fed by the hose coming from the head and return to the one going to the water pump right?
OR
just have It in the same line, so basically just cut the hose from the head, and put the other end of the same hose on the outlet side?
Old Apr 25, 2012 | 12:23 PM
Talyn's Avatar
Talyn
The main problem with running in that way, in my eyes, is that your creating a diversion for the fluid.
It's an example of things taking the easiest path.
The other problem I don't necessarily like about it is there is really no good way to plumb it back in.
If it works, it works. Just doesn't seem the best solution in my eyes.
Old Apr 25, 2012 | 12:26 PM
427 fordman
Not in the same line as its full flow that way. You don't want that. Fed from the head and returned to the top of the water pump line. Or you can just tee into both lines if you wish. Here are a couple examples
https://www.ford-trucks.com/forums/1...coolant+filter
Mine is on page 4 of this thread
0500757Arf
20
Oct 13, 2017 02:59 PM
Kert0307
Jan 22, 2012 08:48 AM
6LPSD
Jan 7, 2009 07:53 AM
wycowboy
18
Apr 10, 2008 02:42 PM
Mykro
Aug 8, 2004 09:58 PM
