NO BOOST HELP!!!!!!
Old Apr 23, 2012 | 07:47 PM
blrman1962's Avatar
blrman1962
NO BOOST HELP!!!!!!
I am driving down the highwat at 60 mph and all of a sudden the truck bucks and has a strange whooshing sound and no boost pressure I cant get the truck over 50 MPH o psi boost 2000 rpm I push the gas to 2500 2800 rpm and get 5 psi boost. I get home usr my AE no codes run all the tests no codes I tested the vacuum pump it works. I started the truck and pulled the vac line on the waste gate there seams to be no vac on that line. I had my wife rev the engine to 200 rpm still no vac on the line and no boost the turbo is spinning I pulled the intake airfilter hose off and I can see the turbo spin.
I need this truck tomorrow anyone HELP
Thanks
Old Apr 23, 2012 | 08:14 PM
joeyd61's Avatar
joeyd61
have you checked the intercooler boots??sounds like you blew one
Old Apr 23, 2012 | 08:25 PM
bcaughhorn's Avatar
bcaughhorn
surely what it sounds like to me. and if i remember rite you dont build boost in park just reving it up. gotta have a load on it. use the pvc cap and build the test piece and blow air through it. you will hear the leak
Old Apr 23, 2012 | 09:30 PM
JOHN2001's Avatar
JOHN2001
If you put it in gear and brake torque it you do but thats about it.
I agree with these guys
Old Apr 23, 2012 | 10:24 PM
PaysonPSD's Avatar
PaysonPSD
The red line going to the wastegate actuator is a pessure line, not a vacuum line.
Like mentioned already, check the boots at the spider, below the spider and at the intercooler.
snakedoc
38
Aug 31, 2011 12:51 PM
bakerbuilttracks
Oct 16, 2008 10:00 PM
cant remember
25
Nov 13, 2006 12:16 PM
Steve_250
19
Jun 25, 2005 09:05 PM
