1. Why do the trucks have 2 batteries, do they serve separate purposes? Or do they work together for one purpose (starting the truck I would guess).
2. If you need to jump the truck, which battery do you hook up to jump!?
Cheers,
1. Diesels have abnormally high compression and you have to feed the glow plugs = Hi current draw.
2. Preferably the pasenger side but either side will work. They are in parallel.
[SIZE="4"]Ol hotrod was visiting another diesel website yesterday and hit on a weird post. Op had taken both batts out and made up 2 sets of capacitors for starting his diesel. Reportedly spun / cranked at a higher rpm and started right now. Had pics of the setup posted.
I inquired about 'what if eng probs prevented quick start, and prolonged crank was needed?' Reply was that only cranked for about 5 - 6 sec's then taper to nil. Recharge was via reg charger, but very quick recharge on the capacitors.
Prolly sev other ??'s to be asked, and answered. So be it, but it was interesting reading...[/SIZE]
