AE dtc's
Old Apr 23, 2012 | 05:20 PM
JT250's Avatar
JT250
AE dtc's
Okay I have
P1876 transfer case 2. Wheel drive solenoid circuit failure
U1058 invalid or missing data for transmission
u1262 comm bus fault
Anyone know what these mean?
Old Apr 23, 2012 | 05:31 PM
JT250's Avatar
JT250
Also got a
P0476 Exhaust pressure control valve range/performance
after running a KOER test
Old Apr 23, 2012 | 07:38 PM
F350-6's Avatar
F350-6
Just a word of advice, don't run KOER tests unless you're trying to diagnose something. When you hook up AE and strange codes show up with no symptoms to match, just clear the codes and see what comes back.
I've seen all sorts of strange random codes show up using AE on my truck. Several of them were for parts my truck doesn't even have. I just ignore the stuff that seems random or doesn't make sense based on how the truck is running when codes pop up.
Old Apr 23, 2012 | 09:06 PM
JT250's Avatar
JT250
Okay so what about the other ones. Those are there every time I hook up to AE. I clear them and they come back.
Old Apr 24, 2012 | 05:49 AM
Tugly's Avatar
Tugly
That comm bus fault concerns me more than the others. That means something is not talking to the other devices, or something thinks a device is out there to talk to, but it doesn't exist. I'd check all your connections on your transmission. Make sure they're clean and locked. Did you do any mods to your truck?
Old Apr 24, 2012 | 09:02 AM
JT250's Avatar
JT250
Not recently...I had the granny rebuilt a couple years ago.
Treytaw
Apr 19, 2013 06:23 AM
duncannon6
Bronco II
Oct 30, 2006 01:23 PM
Jrock909
Nov 28, 2004 07:07 AM
Trexx
Bronco II
Dec 8, 2003 03:12 PM
