waterpump/backing plate question
Old May 1, 2003 | 04:52 PM
mclaughlin31's Avatar
mclaughlin31
I am doing a resto-mod on a 1977 f-100 2wd. Have the 460 and the TCI C-6 all installed. Ordered a edelbrock waterpump for it, Edelbrock says to use ford's backing plate C8SZ-8508a. My question is, when I tore this engine down for the rebuild, there was no backing plate on the water pump. Was a ford waterpump.
Now this is a truck 460 with the steel timing cover and not the aluminum(if that matters). Do I need this backing plate? Did the previous owner of this 460 goof? It had been worked on before, so it's not stock, not sure whether I need this backing plate, I haven't cut any corners as of yet and am not ready to start.
Thanks for any help.
BTW this is a 79 460 if that matters.
Mac in Maine
Old May 1, 2003 | 05:02 PM
classic79's Avatar
classic79
I always thought that all 460 had the aluminum front cover.
Old May 1, 2003 | 05:12 PM
mclaughlin31
I was told that the truck blocks had the cast steel timing cover. Mine is definately steel. Heavy as hell:-)
Mac in Maine
part number D1JE-8059-AA
I had asked my machinist to wash my timing cover and he said he couldn't because all the 460 covers were aluminum. I took it up to him and he said that was the first steel timing cover he had seen on a 460(but they deal alot more in "the other brand")
Old May 1, 2003 | 07:47 PM
BentWheel's Avatar
BentWheel
what's the front of the cover look like where the pump bolts on, ie flat, recessed?
Old May 1, 2003 | 08:08 PM
georgedavila's Avatar
georgedavila
I've torn down a few car and truck 460 engines and never found anything but alloy timing cover cases. I haven'd messed with the early Lincoln 460 which had the power steering pump mounted there, maybe that's a possibility?
Old May 1, 2003 | 09:25 PM
mclaughlin31
The front of the cover is flat, with only holes on the left and right side. There are no indents, no empty pockets, no nothing, other than the one hole on each side.
Old May 2, 2003 | 12:39 AM
BentWheel's Avatar
BentWheel
Sound like it should be fine without a backing plate then.
Old May 2, 2003 | 01:51 AM
merc460's Avatar
merc460
I to have torn down a few truck and car 460 and only found alloy front covers, saying that several 370 engine's I have worked on did use a cast iron cover because the front motor mount was incorperated into the cover. Eric
Old May 2, 2003 | 07:55 PM
mclaughlin31
According to the "J" in the casting number D1JE-8059-AA . It is for "industrial"....whatever use that was?
Mac in Maine
Old Dec 12, 2007 | 06:07 PM
jlanza's Avatar
jlanza
Can't find part
were you ever able to find this part (DIJE-8059 AA). I have a bad timing cover from an OMC 460 and I can't find a replacement cover anywhere. All the 460 timing covers do not look like the one I have.
Old Dec 12, 2007 | 07:23 PM
mclaughlin31
That was the part I had. I ended up buying an aluminum stock cover since I couldnt get the elderbrock water pump to seal correctly. Can't remember the reason for it now, think the gasket wouldnt line up with the cover correctly. Hope that helps. Been a while
James
justin90gsx
Aug 8, 2015 10:59 PM
matacemat
Jun 4, 2013 08:53 PM
crazy96863
Feb 17, 2013 12:57 PM
scottddove
Feb 21, 2009 09:52 PM
