fuel gauge reading problems
Old Apr 23, 2012 | 08:38 AM
XTfx4's Avatar
XTfx4
hi all , my fuel gauge never went to full always went to 3/4.. last fill up only went to half....? where is the problem ,is it the sending unit , the float in the tank, or is it in the gauge itself in the dash? thanks for any help
Old Apr 23, 2012 | 08:46 AM
mikeo0o0o0's Avatar
mikeo0o0o0
First, unplug the sending unit and ground the wire that comes from the gauge. Turn the ignition on and watch the gauge. If it swings all the way to "full" everything from the wire back to the gauge is good.
My guess is the float has become fuel logged and is partially sunk. The floats are brass and soldered together, these crack and soak up fuel.
The floats are still available. Dennis Carpenter has an "improved" version that doesn't crack and sink.
Old Apr 23, 2012 | 12:47 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by mikeo0o0o0
The floats are brass and soldered together.
The float is made from two pieces of copper soldered together. Solder breaks down, gas seeps in, float settles to the bottom of the tank.
COAZ-9202-B (replaced COAZ-9202-A & B7A-9202-A) .. Fuel Sending Unit Float / Available from Ford.
MSRP: $15.94 // FTE Ford Dealer Parts Dept sponsor tousleyfordparts.com price: $10.52.
Applications: ALL 1957/79 Passenger Cars/Trucks / 1961/79 Econolines & 1966/79 Bronco's.
1977_f10028
Apr 26, 2019 01:04 PM
Spoonman75
Sep 18, 2015 12:39 PM
wrdabney
Feb 4, 2015 04:18 PM
Dimmick24
Nov 23, 2013 02:46 PM
Old blue72
Oct 2, 2010 08:09 AM
