Fuel Gauge Does NOT Work
Old Aug 8, 2011 | 11:49 AM
Dimmick24's Avatar
Dimmick24
Arrow Fuel Gauge Does NOT Work
Hello agian, I bought my 1973 F-100 2WD M/T, and the fuel gauge hasn't worked. I haven't had time to check it out, since four days after I bought it, The motor blew. Now that I have replaced the motor, I would love to be able to see my fuel level, especially with and Edelbrock 4 Barrel. If you have any info, It would be GREATLY appreciated!! Thanks
Old Aug 8, 2011 | 12:04 PM
BoomerTexas70's's Avatar
BoomerTexas70's
You may have to check the float on the sending unit in the tank. But first you want to look at the wire to it, look for cut/broken or possible came unplugged. Always want to think simple before getting into a mess of things and making it difficult.
Boomer
Old Aug 8, 2011 | 12:13 PM
dakonthemountain's Avatar
dakonthemountain
If you ground out the gauge and it peaks, your gauge is good and it is either a connection, as above, or the sending unit. You can also do this at the tank to eliminate any problems between... Good luck!
Dak
Old Aug 8, 2011 | 12:14 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The float is made from two pieces of copper soldered together. Solder breaks down, gas seeps in, float settles to the bottom of the tank.
COAZ-9202-B .. Fuel Sending Unit Float / Available from Ford.
Applications: ALL 1957/79 Passenger Cars/Trucks / 1961/79 Econolines / 1966/79 Bronco's.
Old Aug 8, 2011 | 12:41 PM
co425's Avatar
co425
Check your wires first. Mine wad unplugged behin the dash. I believe it's an orange wire but check your wiring diagram.
Old Aug 8, 2011 | 01:34 PM
HIO Silver's Avatar
HIO Silver
... and remember to again thank your "genius uncle"! LOL.
Old Aug 8, 2011 | 02:16 PM
Dimmick24's Avatar
Dimmick24
What exactly do you mean ground it out?
Old Aug 26, 2011 | 10:39 AM
blueovalfan1's Avatar
blueovalfan1
I am working on my 78 F150 gauge right now. It does nothing at any time. I just disconnected the wiring near the tank, grounded it and it pegged. Does that mean it is for sure the sending unit?
Old Nov 23, 2013 | 02:39 PM
erik68's Avatar
erik68
fuel guage wont work
on my 77 ford i put the tank that was behind the seat in the bed.gas guage wont work.when i touch the power wire to the groud the needle moves all the way up.i have it grounded at the back of the cab.
any help?
Old Nov 23, 2013 | 02:46 PM
fmc400's Avatar
fmc400
MSEE
Check the resistance of the sending unit in the EMPTY and FULL positions.
1977_f10028
Apr 26, 2019 01:04 PM
Spoonman75
Sep 18, 2015 12:39 PM
XTfx4
Apr 23, 2012 12:47 PM
kevinthefordman
Jul 30, 2011 02:00 AM
undertakerman
Jul 25, 2010 02:30 PM
