Sponsored by: Real Truck
Heat-A/C blower
Old Apr 22, 2012 | 03:28 PM
4bigred's Avatar
4bigred
Heat-A/C blower
Out of the blue the fan will only run on the highest setting. I have both steering and dash controls so I don't think it's something inside the cab. I lowered the temp control to 60 and it didn't make any difference. Thanks
Old Apr 22, 2012 | 04:07 PM
dchamberlain's Avatar
dchamberlain
Try this procedure and see if it comes up with any codes. If it does I can probably look them up and point you in the right direction. It might be the speed controller, but I don't think I've seen an EATC do this. It's usually the manual controls when the resisters fail.
https://www.ford-trucks.com/forums/1...l#post11347861
Old Apr 22, 2012 | 05:22 PM
4bigred's Avatar
4bigred
I tried the self test. After I cycled the key on/off and hit off/defrost buttons and then auto nothing happened. It just displayed auto, ac, and the temp it was set to. I must be doing something wrong, but I tried it several times and had printed the instructions.
Old Apr 22, 2012 | 05:27 PM
dchamberlain
What year is your truck? Maybe it's different.
Old Apr 22, 2012 | 05:33 PM
4bigred's Avatar
4bigred
It's a 2006 F250
Old Apr 22, 2012 | 06:53 PM
dchamberlain
I think this is pretty much the same procedure but maybe goes more in-depth. I'd start with the EATC self-test then try the diagnostic codes.
File Type: pdf
Old Apr 22, 2012 | 07:47 PM
4bigred's Avatar
4bigred
I got the self test to run. It came up with a -188. I didn't see that code in PDF you sent. Before I forget, thanks a lot for the help.
duvaller
Sep 3, 2015 02:18 PM
jasfaa
Aug 31, 2008 02:04 PM
nordy racer
Apr 18, 2008 08:55 PM
jas88
May 13, 2004 09:54 PM
demerson1
Feb 27, 2004 10:18 PM
