Brake light issue
Old Sep 12, 2018 | 11:30 AM
AmericasFinest's Avatar
AmericasFinest
Brake light issue
I just bought a 1976 F-150 and the brake lights don't work. The turn signals work. The hazards don't work unless you already have the blinker on. I have power going to the brake switch and the switch itself is good.
I did a continuity test on the output wire on the brake switch and it looks like it is wired to ground but it doesn't blow a fuse when I use the brake. Could it be a problem with the turn signal switch?
Also I would like to mention that ALL of the other lights work (Except the license plate lights, which are missing)
Picture of the turn signal switch
Old Sep 12, 2018 | 12:53 PM
meangreen92's Avatar
meangreen92
Maybe the hazards have a bad or missing flasher?
I forget - does the brake light switch control the positive side or the negative side of the circuit? Thought it was positive on these old Fords, but it's been a while since I've had to mess with one.
The brake lights do go through the turn signal switch, but you want to make sure that the bulbs and sockets are truly good before proceeding much further. The sockets have been known to go bad. You can test continuity from the contact back to its wire, and be sure. Also you can pull the connector off of the brake light switch and make sure the switch makes continuity when the pedal is pushed down.
That said, my old '68 Cougar lost its brake lights, and I traced it to the turn signal switch. I ended up running a jumper wire in the switch to get my brake lights back.
And welcome to FTE!
Old Sep 13, 2018 | 07:42 PM
AmericasFinest
I ended up running a new power wire to the input of the brake switch and it solved my problem.
Thanks for the advice though!
Old Sep 13, 2018 | 08:09 PM
deich's Avatar
deich
Mine gave me fits... Turns out it was the turn signal switch...
Old Sep 22, 2018 | 12:50 PM
niko20's Avatar
niko20
And welcome to FTE!
yep I had a bad socket on my rear passenger brake lamp, for the backup light. Couldn't believe it, I have never in my life seen a bad socket.
Redneckrucker16
Jul 22, 2014 12:05 PM
darinbrooks
Dec 1, 2010 06:23 AM
tardster
15
Apr 4, 2010 06:15 PM
toolman617
Electrical Systems/Wiring
Aug 3, 2005 03:37 PM
gearjammer26
Mar 6, 2005 09:19 PM
