8.8 yoke question
Old Apr 21, 2012 | 03:56 PM
Dead Truck's Avatar
Dead Truck
8.8 yoke question
I have an 87 F150 8.8 that needs replaced. I just picked up an 89 rear but it has a different yoke, one that has a round flange on it. I don't have mine here to look at, can't see it til Monday. So my question is will I be able to simply swap yokes so my '87 driveshaft fits? I do know my 87 does not have the round flange.
Old Apr 21, 2012 | 08:21 PM
BigBlueOx's Avatar
BigBlueOx
The easiest thing to do is put the round mating flange that goes on the driveshaft onto your driveshaft or install the driveshaft out of the doner truck(if it's the correct length)
Old Apr 26, 2012 | 12:26 AM
Dead Truck's Avatar
Dead Truck
Donor driveshaft too short. From a 4x4. So will the yokes interchange?
Old Apr 26, 2012 | 02:12 AM
rangergirl94's Avatar
rangergirl94
Ive never seen an 8.8 that didnt have the flat plate??
Old Apr 26, 2012 | 12:01 PM
Dead Truck's Avatar
Dead Truck
My 1987 does not have it
Old Apr 26, 2012 | 04:28 PM
EPNCSU2006's Avatar
EPNCSU2006
You should be able to swap the yokes, but you will need to measure the pinion bearing preload before taking it apart. You will also need a new crush sleeve and may as well replace the pinion seal while you can get to it. Then torque the new pinion nut little by little until you get back to the original pinion bearing preload.
ErrorS
Nov 22, 2010 12:27 PM
needs more mudd
Apr 7, 2008 01:48 PM
fattmann
Apr 16, 2006 01:45 AM
1995Ford250
Mar 28, 2006 03:42 AM
oldhalftons
1978 - 1996 Big Bronco
Feb 29, 2004 06:11 PM
