the pre-bent cage went well until the a pillar bars were tacked in, the dash pad would not work and the cage could not be moved back because the window cranks would not be operable. then someone cut all the hood latch brackets off the grill anther set back. So it got put on the back burner and worked on a few other projects. So today I met with a guy to bend me up some new bars and we will be back on this project in no time.
Glad it is now going so quickly. Guess you'll drive it to the GTG?
Went to the Owasso FFA car show today. If I'd have known about it, the Thunderbird would have been there. Any way, I did take a picture of this Bronco there and thought of JW.
JW was at my place for the get-together. And, why weren't you?
No the bronco mike posted about, it's complete. I'm still working on mine. I have a 65 Chevy in the shop we are trying to push out so my bronco on the back burner again.
Ok, then I've seen that Bronco but haven't stopped to look at it. Will do. Tnx.
