97 7.3 temp guage problems
Old Apr 20, 2012 | 11:58 AM
jbrandall89's Avatar
jbrandall89
Got 97 f-250 temp gauge seems to not be working right. after warms up gauge goes mid way of normal. If on the freeway or towing it goes all most to the end of the normal. i changed the sending unit with a aftermarket one and have had same results. any advice? thanks
Old Apr 20, 2012 | 12:22 PM
DIYMechanic's Avatar
DIYMechanic
What do you mean by "the end of normal"? The cold end or the hot end? Is it running cold or running really hot?
Old Apr 20, 2012 | 12:27 PM
jbrandall89
its on the hot side of normal. i put a after market temp guage on to make sure it wasnt running hot which it isnt. just wondering what would be best way to fix it or if there could be another problem?
Old Apr 20, 2012 | 12:51 PM
DIYMechanic
It has to be either the sending unit, the wiring, or the gauge itself. How is that for narrowing it down !? LOL.
The way that system works, the sending unit is just a thermistor that reduces it's resistance progressively over a given temperature range. To test the gauge, you can ground the signal wire directly to a ground and when you turn on the key, the needle should peg to the hot side. If that works, I would look closely at the wiring and make sure there aren't any places that are skinned and could be contacting the engine block or chassis.
Am I correct in my understanding that you have changed the sending unit and it still behaves the same? When you connected the aftermarket gauge did you use a different sending unit or the stock one?
Old Apr 20, 2012 | 07:00 PM
fordpride's Avatar
fordpride
Did you change the right sending unit? We have two one for the temp light and one for the gauge
Old Apr 20, 2012 | 07:12 PM
fordpride's Avatar
fordpride
jimlj
Electrical Systems/Wiring
Jul 28, 2007 08:37 PM
jclark4cs
Mar 19, 2006 10:15 PM
DouginTahoe
Apr 19, 2005 08:11 PM
415dave
Nov 17, 2003 05:11 AM
Ken2600
18
May 9, 2003 10:09 AM
