Transmission/engine plate noise
Old Apr 20, 2012 | 09:45 AM
kconrad's Avatar
kconrad
Ok guys. I have removed the plate that is vertical between the transmission and engine and put high temp sealant around it to keep it from vibrating. Well the noise is back again. I have not taken the plate off but I know that the noise is that plate again. How important is that plate? Can it be removed? If not, what are other fixes.
Old Apr 20, 2012 | 10:14 AM
Bigpapa346's Avatar
Bigpapa346
Leave it on, that is an inspection plate that exposes the flywheel and torque convertor. While these are not really internal engine components I don't suggest leaving them exposed to the elements.
I went to the hardware store and picked up some thin rope style insulation for screen doors and such. Sticky on one side, I simply lined the portion of the plate that contacts the trans and done. No more rattle..
Old Apr 20, 2012 | 10:20 AM
kconrad's Avatar
kconrad
OK, I will try that. Thanks
'74 Ford 250 CS
39
Aug 4, 2018 10:37 AM
olblue77
Sep 27, 2017 04:11 PM
socalheel
Jun 12, 2016 09:50 AM
A/Ox4
25
Nov 12, 2014 03:22 PM
terry_opie
Modular V10 (6.8l)
Nov 9, 2010 02:19 PM
