Bad injectors or what???
Need help please, 2000 350 7.3 420000 just started acting like the valve cover gasket wires has a bad connection, changed gasket did not help .If you turn the key off and on several times it will go ahead and run fine,shut it off and may do it again ,repeat same thing with key it runs fine . Sounds all most like it is running out of fuel or just a few are firing. Need to do buzz test but do not have scanner,anyother way to tell if injectors are working.
Nick Baker
Mar 2, 2019 10:10 PM
R1racer
Apr 5, 2017 08:47 AM
derrickmauk1003
Aug 6, 2015 07:53 PM
ford 300
Sep 24, 2012 07:51 PM
