intercooler
Old Apr 20, 2012 | 05:28 AM
Liquid10Rider's Avatar
Liquid10Rider
intercooler
Im really considering a new intercooler since I have heard they do lower EGT and help with the trans cooling. My question is if I bought an intercooler from lets say silverstateford for a 6.0 will it be a drop in replacement for my 01 f250? If not where could I get something that will help reduce trans temp and egt and not break the bank?
thanks,
-AJ
Old Apr 20, 2012 | 06:12 AM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
how much is breaking the bank? the 6oh i/c will fit in the stock location but youll need new boots for the tube to i/c connection....imo its better to get something like a spearco - tapercore - or DI i/c.......they arent cheap but worth it.....somebody on here runs a spearco and i run a tapercore.....i love my tapercore but it comes with a hefty price....you can get one a little cheaper than the tapercore by getting a spearco or DI unit but its only like 200 bucks cheaper.....the tapercore is MASSIVE.....
Old Apr 20, 2012 | 06:22 AM
CSIPSD's Avatar
CSIPSD
No intercooler will effect trans temps, they have nothing to do with each other.
6.0 ic is a waste of money, does not drop temps in anyway.
Old Apr 20, 2012 | 06:26 AM
indyF-350psd
good catch joe....totally missed the trans part.....
Old Apr 20, 2012 | 08:15 AM
Liquid10Rider
now the reason that im looking into an intercooler is because the other day when towing i was pushing about 1000 to 1100 egt and 200 trans temp stock. If i was to cool the trans down would i have to get a different trans cooler? and for the egt the intercooler would work??
breaking the bank would be 1500 or more but if it will help ill have to spend the extra money. If i was going to do something id want something priced well and something that will perform great.
thanks,
-AJ
Old Apr 20, 2012 | 08:31 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
thanks,
-AJ
I would invest in a 6.0 trans cooler before the 6.0 IC. If you are towing hills, that temp on EGT is fine. Also depends on what tune you are towing in with the Bully dog chip.
Old Apr 20, 2012 | 09:01 AM
jwhitetail's Avatar
jwhitetail
I have a SPERACO 6.0 which requires taking the front bumper off so you can relocate or bend the trans cooler lines and space the radiator because it's twice as big as FORDS!!, and if someone on here does not think it lower's egt's, think again.
Old Apr 20, 2012 | 09:04 AM
Liquid10Rider
I'm using the stock setting on my chip. Now where could I find a 6.0 trans cooler? And is it a direct replacement? Also riff raff has a deep trans pan with cooling fins. Would I be worth wild to maybe look into that along with the cooler?
Old Apr 20, 2012 | 10:10 AM
timmyboy76's Avatar
timmyboy76
check for leaks on the up pipes, and around where the CAC boots are. If must, remove the tubes, and clean the boots if nasty looking. if soot is present on top where the up pipes collect to the collector (behind turbo), then that would add to higher egt #'s.
Old Apr 22, 2012 | 01:25 AM
Pitcrw6's Avatar
Pitcrw6
You can get the 6.0 trans cooler from Clay (riffraff) or Tousely Ford and yes it will drop right in but the fittings are different but you can get those from Clay also or your local hardware store. I wouldnt get the deep trans pan if you get the trans cooler. Your temps will drop alot with the 6.0 trans cooler. I have the Banks I/C and it dropped my EGT's 250* but it was pricey. I plan on getting another I/C for my X when the money comes available.
Old Apr 22, 2012 | 09:08 AM
Liquid10Rider
Thank you for the info. And I looked on clays site but couldn't find the trans cooler? I did find the IC though thanks again. Ill give clay a call monday
-AJ
Old Apr 22, 2012 | 11:53 AM
Pitcrw6's Avatar
Pitcrw6
He must have discontinued them. I was just looking at them 2 weeks ago under Hot New Products on his home page and he was selling them for $308 I believe. Thats a bummer.
Pigpen1
Jun 14, 2016 08:29 AM
superrman77
Mar 24, 2011 08:34 AM
Adam0331
13
Mar 2, 2009 02:55 PM
Dustball8504
May 5, 2008 08:27 AM
shockzone
Apr 22, 2008 03:33 AM
