ABS and speedo problems
Old Apr 19, 2012 | 02:23 PM
tbomber7's Avatar
tbomber7
2004 f350 6.0l. Abs light is on cruise doesntwork andspeedo doesnt work.
Old Apr 19, 2012 | 03:33 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Maybe VSS (vehicle speed sensor)? Think it's in the rear differential.
Old Apr 20, 2012 | 10:49 AM
run6.0run's Avatar
run6.0run
I think it might be more than just the vss, or even the harness. If there is a failure in the rear vss, the pcm then looks to one of the front abs sensors for speed input. And the cruise should work while the abs light is on(that is, if its your rear vss). The cruise and speedo will momentarilly not work with a rear vss failure, but then will start working when the pcm starts looking at the front sensors
for input. At least that was how my truck acted when my rear vss harness went bad.
Old Apr 20, 2012 | 02:31 PM
dchamberlain's Avatar
dchamberlain
I can't speak for your truck, but there have been many, many reported cases of a failed VSS causing the speedometer to quit working, the ABS light to come on, the Tow/Haul light to flash and the transmission shift patterns to go to hell.
In most cases, replacing the VSS solves this problems. In fewer cases there is a wiring harness issue.
At least that's what I've observed over the years here. The VSS is held to the top of the differential case with one bolt and is not difficult to change.
Old Apr 20, 2012 | 03:40 PM
tbomber7's Avatar
tbomber7
Does any one know how to test the vss
Old Apr 20, 2012 | 08:10 PM
Ford 1443's Avatar
Ford 1443
4wd Low
About 8 months ago, I had the same problem. I replaced the rear VSS sensor and spent countless hours pinning the harness. Finally gave up and took it to the dealer, turned out to be a burnt circuit board in the windshield wiper motor.
Sounds strange, they replaced it and I haven't had a problem yet.
62FE4x4
May 25, 2016 06:33 AM
1976and2001_250
Apr 18, 2011 09:20 PM
lee231
Aug 16, 2009 09:37 PM
dodgefreak8
Sep 8, 2008 03:34 PM
Rangerman255
1983 - 2012 Ranger & B-Series
Sep 18, 2003 07:17 PM
