Another idea (probably wont work)
Old Apr 19, 2012 | 04:34 AM
86f250XLT-4x4's Avatar
86f250XLT-4x4
Ok I was thinking these engines are known for hot oil and I have an oil temp gauge and my 6.9 easily reaches 230 my parts truck has a good ac system on it.... I was thinking I could take the condenser off and clean it out.... And use it as an added oil cooler? Just run it off of one of the high pressure oil ports and just let it feed back in to something such as the cdr hole (just like a turbo would)
Old Apr 19, 2012 | 07:47 AM
tjc transport's Avatar
tjc transport
i ain't rite
you already have an oil cooler on the driver side of the block. the oil should be a little hotter than the coolant temp.
Old Apr 19, 2012 | 10:45 AM
eatont9999's Avatar
eatont9999
Yeah, don't waste your time. All you will wind up doing is creating more potential for oil leaks and over-complicating the oil system opening it up to more failure points.
Old Apr 19, 2012 | 11:55 AM
444dieselrod's Avatar
444dieselrod
230 is perfect. Hot enough to boil the water out but not crazy hot.
Old Apr 19, 2012 | 01:00 PM
Ford4Life7.3's Avatar
Ford4Life7.3
Heres how one of the PSD guys did his, its on page one...https://www.ford-trucks.com/forums/1...-or-small.html It looks like he used a tranny cooler of some sort, but an AC one wouldn't do to bad i guess.
Old Apr 19, 2012 | 02:17 PM
eatont9999's Avatar
eatont9999
I could see cooling the oil pre-turbo to lower the bearing temps but I have never had oil-heat issues in my IDI.
If you do add a oil cooler, solder on some compression fittings and use braided steel oil line that way leaks are less likely.
Old Apr 19, 2012 | 08:57 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
what your doing is ok imho.but don't do it without an external oil t-sat.
444dieselrod brings up a valuable point.you want the heat to rid condensation in the oil.
something like this would work well.but 80C is't even 180 degree's.
http://www.demon-tweeks.co.uk/Produc...%20Accessories
get searching.
alternatively,you could swap in a turbo oil cooler.it has more fins than an n/a engine.
if your not turbocharged,and hauling/towing heavy then you probably have nothing to worry about anyway.
these engines do not have a common heating problem fyi.those who say this,have problems and,or,are over gross anyway.
Old Apr 19, 2012 | 11:27 PM
86f250XLT-4x4
Well 230 without a load and I was thinking if it did work and me adding a turbo later (probably having nmb2 build one for me) I was wanting to cool the oil pre cooler put an extra oil filter, and post cooler run a 25 ppm filter for the turbo
Old Apr 19, 2012 | 11:40 PM
86f250XLT-4x4
Forgot to mention I do have an external temp gauge For my oil
polosabre
Jul 29, 2014 03:13 PM
blkdiesel
Aug 13, 2009 03:49 PM
53fatfndr
Jan 29, 2006 06:29 AM
fordfan2018
Oil & Lubrication
Feb 18, 2004 10:55 AM
Jerrybo66
Apr 16, 2003 03:06 AM
