Which block to start???
Old Apr 18, 2012 | 01:57 PM
Caveman2851's Avatar
Caveman2851
OK fellas I just bought a 1960 F250 4x4 and I want to put an inline 6 in her. The 429 that's in her now is newly rebuilt but I want a 6. I will be building (have someone build) the inline 6 from the block up and was wondering which block would be best to start with so I can start checking out yards for one. Also if someone could recommend a head so I can take it to get p&p. I'm looking to build something with plenty of power but good mpg because this will be my daily driver. Thanks
Old Apr 18, 2012 | 02:50 PM
85e150's Avatar
85e150
Any block will do. EFI motors have slightly higher compression. Not sure you can bolt up a carb manifold to the head, but you probably can.
Good mpg in a F250 4x4?
Old Apr 18, 2012 | 03:01 PM
Caveman2851
I have an Edelbrock 4 barrel that I would probably use and put a duel plane manifold & a couple of efy exhaust manifolds on, guess I should have said that to begin with.
Old Apr 18, 2012 | 04:28 PM
Joeseph's Avatar
Joeseph
Being as your running a carb I would imagine a older style block would be easier unless you plan on going with a electric fuel pump. I think the only differences in the blocks are the fuel pumps and the pans but I could be wrong.
Old Apr 18, 2012 | 06:11 PM
fordman75's Avatar
fordman75
I like using any of the 67-79 300 or 67-74 240 blocks.
The head really depends on what you are planning on doing. I would stick with an 86 or older head. The 65-74 240 heads will have a smaller combustion that's good for a .5 bump to the compression ratio. But you can accomplish the same thing with different pistons.
I've never seen an Edelbrock 4V intake for a 300. I knew a long time ago they made a 1V intake.
Old Apr 19, 2012 | 07:00 AM
Caveman2851
Sorry ment an Offy. intake. Does it matter what vehicle I get the block or heads off of? As far as trannys go I already have a C6 but was wondering if there would be an upgrade I should look at. I do about 50/50 highway/city driveing. Thanks again for all the help guys. As soon as I get the truck delivered I'll get some pics posted. She needs a bit of work but I think it will be a great project.
sisabdulax
Nov 19, 2014 06:10 PM
Bossbronco
Sep 21, 2014 09:11 AM
Talyn
26
Apr 4, 2011 11:54 PM
countryF150
Oct 10, 2006 12:03 PM
Scouder
Nov 14, 2004 03:38 PM
