build
Old Sep 20, 2014 | 09:01 PM
Bossbronco's Avatar
Bossbronco
build
I have a carb 300 I'm building. Was wondering if the efi block was compatible? Lighter? Stronger? With the carb setup.
Old Sep 21, 2014 | 09:11 AM
Harte3's Avatar
Harte3
The only real difference between them is that the EFI block does not have an opening for the fuel pump arm but the bolt holes are there. You can use an electric fuel or do as some have done and drill/knock out the block and use a stock mechanical pump.
bl2009
Mar 14, 2018 06:35 PM
pete98cobra
Oct 30, 2016 12:03 PM
DHCowdude
Mar 25, 2011 09:25 AM
71mach1
Apr 20, 2009 07:43 PM
FL_Mudder
Mar 23, 2009 09:30 AM
