Sponsored by: Real Truck
VSS Replacement
Old May 1, 2003 | 06:01 AM
Scotts99PSD's Avatar
Scotts99PSD
VSS Replacement
I replace my VSS yesterday. When I pulled the old VSS out, there were "fingers" of fluid on it, thought it was metal pieces but it was little more than fluid with (I assume) some metallic particles in it. I assume the VSS is a magnet and so would attract any metal filings in the rear end. Should I pull the diff cover and check things out, or is this normal?
Old May 1, 2003 | 06:47 AM
powerstroker250's Avatar
powerstroker250
VSS Replacement
If there was in fact metallic particles on the sensor, I would change the fluid.
Les
Phy
Dec 11, 2014 12:06 AM
jbaynor
Dec 23, 2012 09:28 PM
thordehr
19
Nov 22, 2010 11:09 PM
bigolfordtruck
Dec 17, 2007 11:36 PM
ajordan193
Oct 29, 2006 12:16 AM
