What yr truck ,model etc!!!!!!
the vss is located on the top off the rear diff ,1 small hex bolt besure to clean around the area before removing .
Also ch that the wiring is in good shape.
you may also have a broken front abs sensor.
A common symptom of the rear one being bad is the tranny shifting funny or speedo stops working or acts funny.
you can scan it to get the exact code for which one is failing.
Rich
Rich
2001 F250 V10 ext cab 40k miles. Wiring should be good truck is mint.
