Tire balancing, no weights?
Old Apr 16, 2012 | 06:35 PM
gymbo88's Avatar
gymbo88
I had four new tires installed at America's Tire, just a few days ago. Today, I noticed that the two rear tires had no balancing weights. I did not get on the ground, to check if the weights were possibly mounted on the inside. Is it possible the tires balance OK without weights? Is it common, or perhaps they just forgot to balance them?
Old Apr 16, 2012 | 06:44 PM
danorules's Avatar
danorules
sometimes you get lucky and dont need weights, sometimes they are weighted on the inside of the rim, or inside the tire with powders or calcium.
and dont forget the tire installer error, installing the weight but not crimping it tight enough to withstand "real world" driving
if you dont have any vibrations you should be fine, but any little bit of shaking and i would return to the tire shop immediately
Old Apr 16, 2012 | 07:16 PM
Coskid's Avatar
Coskid
Mine are weighed on the inside of the rim and took a very small amount to balance them correctly.
tigman_tim
Sep 9, 2010 04:16 PM
Orezona
19
May 22, 2009 08:12 PM
dynamic
Mar 22, 2009 09:24 PM
Storm
Jun 4, 2007 05:45 PM
mudgepondexpress
Sep 27, 2005 05:00 PM
