ECM not readable is it dead
Old Apr 16, 2012 | 08:51 AM
oldiron2112's Avatar
oldiron2112
I have a 1994 F350 7.5l 4x4 5speed. I ham not able to read ECM codes. I have a tried a couple different ODB1 readers and the have tried to jump the port and only get a solid check engine light .
Is the ECM fried?
Thanks,
Bryan
Old Apr 16, 2012 | 09:16 AM
Conanski's Avatar
Conanski
You are connecting the single STI wire to the code readers along with the main test conector right?
Does the engine run? if so then your ECM isn't fried but you may have a broken wire between the test connector and computer. The 3 main signals are STO(pin 17), STI(pin 48), and Sig-Rtn(pin 46), I suggest disconnecing the harness from the ECM(after discomnnecting the battery) and probe these wires with a multimeter to ensure continuity, and if you find an open track down and repair the break.
Old Apr 16, 2012 | 09:34 AM
oldiron2112
The motor does run, just not well, and we have eliminated any obvious issues.
I have pulled th ECM and did a physical check of the pins and wires. There was no corrison or fraid wires.
I will put a meter to the the wires and check continuity.
Thanks,
B
Old Apr 16, 2012 | 12:34 PM
subford's Avatar
subford
Yes it is a fried ECM?
Open it and see if you can see were it is fried.
At least the clock in the computer is still working.
jackietreehorn
Sep 3, 2017 11:18 AM
mrb455
22
Oct 1, 2009 09:38 PM
LARIAT 85
Jun 20, 2007 08:43 PM
moondogg
Nov 15, 2004 06:30 AM
Gates
Nov 6, 2002 07:57 AM
