Changed coolant, now I have a leak
Since were on the friggin' subject what should I put in my OBS? I was just going to stick some prestone (green) in it. Open to suggestions. Btw CAT dealer near me, no international. Whatever is easiest/cheapest with best heavy duty protection this is all new too me, checked out the link from powerstrokenation feel a lil more confused...
Here's the fleet charge some of us are using.
Glenn how long after you put in the fleet charge did you test the sca level. Since its precharged i know it will last a while at the right level, but for how long? And where do you get the SCA test strips?
Antifreeze/Coolant Peak HD FLEET - Engine Coolant / Anti-Freeze | O'Reilly Auto Parts
If you can get both block plugs out and drain all the coolant, 8 gallons (4 gal of coolant and 4 of water). When flushed mine a month ago i couldnt get my driver side block plug out and i got in 4 gallons of coolant and 2 gallons of water.
Use distilled water with the mix. Blake's got you hooked up with good coolant and the amount.
Blake, I got my test strips at napa, but I haven't even checked it yet. I just changed it and put that coolant in and a need release coolant filter along with it so haven't bothered to look at it yet..
Darin what do you mean 'need release' coolant filter
Basically a pre-charged coolant filter that slowly releases SCA?
Or is it something smarter that literally tests the coolant and releases the correct amount of SCA?
I tend to think its the first rather than the latter..
but still curious!
but still curious!
Penray NF2088 Coolant Filter w/ Need Release | eBay
That is the one I have guys. Alex, that is what it is supposed to do is release needed sca's as necessary. It is supposed to be smart like you said..
Glenn, I'll have to try one of the test strips one of these days. I'll let you know when I do. My local napa didn't have them in stock but ordered them for me. Napa brand I believe.
https://www.ford-trucks.com/forums/1...p-started.html
My coolant thread writeup is at the end of this thread, last page or two.
drbigknuckles
01-28-2009 04:05 AM
