2004 Sport Trac Auxiliary A/C
Does anyone know why the rear Auxiliary A/C blower on a 2004 Sport Trac keeps blowing fuses and how to fix it?
Thanks,
Wrb36usa (wrb36us@aol.com)
Thanks,
Thanks shorod,
You are correct. When I insert the right fuse and run the blower on low, it works just find.
But, when I turn the blower to a higher speed it blows the fuse.
Can you tell what my next move should be?
It sounds like the problem is the blower motor itself then. If it were a direct short to ground, the fuse would blow anyway. Instead, it sounds like you may have an issue with the blower that is causing it to draw more current than the circuit is rated for. It could be a bearing that is worn and loading the motor, it may be an issue with the motor windings.
From what I can tell of the wiring diagram, it appears for low speed the blower motor is just along for the ride, probably relying on airflow from the cabin blower motor. For Medium speed the ground for the rear blower is routed through a resistor which effectively limits circuit current, keeping the fuse from blowing. When on High speed, the rear blower has a straight path to ground through the rear blower control switch, no current limiting. There is a thermal fuse in the rear blower motor resistor block, but that thermal fuse is in circuit regardless of speed setting.
-Rod
-Rod
The rear blower motor is located in the center console, underneath the storage compartment. You need to remove the console to replace it. It doesn't appear to be a trivial task. If you'd like a copy of the service manual removal and reinstallation procedure, send me a Private Message with the request and an e-mail address for you and I'll send you the PDF procedure.
-Rod
-Rod
-Rod
-Rod
I do not know how to send a private message on this web site. Please email me at: wrb36us@aol.co with the PDF file you mentioned in your post to me about the below Quote.
Thanks,
Bill
-Rod
The electrical draw exceeds the fuse rating....
Either a bad blower motor or a ground/short on the circuit.... Philip
