Help!!
Old Apr 15, 2012 | 04:09 PM
Brent Martin's Avatar
Brent Martin
Help!!
I have always been a ford truck fan but im new to the site and also new to diesels i just recently checked my fluids and i noticed im in dire need of tranny fluid it isnt bone dry but it could def. use some i get to looking around for what kind goes in but the numbers i found arent matching autozone's and o'reilies numbers i currently own a 1999 F-250 super duty with the 7.3 turbo diesel can anyone tell me where to find what fluid i use?
Old Apr 15, 2012 | 04:15 PM
nlemerise's Avatar
nlemerise
You use Mercon V in the tranny...
Old Apr 15, 2012 | 06:38 PM
Brent Martin
thank you for the response honestly didnt think id get one
Old Apr 15, 2012 | 06:49 PM
megawatt00's Avatar
megawatt00
Welcome to FTE and or neck of the internet. You will always get an answer here, we were all newbies at one point.
Don't feel bad about asking questions the only dumb question is the one that you don't ask.
Old Apr 16, 2012 | 08:03 AM
Greek 350's Avatar
Greek 350
I went throught this same experience recently. The problem is that when your truck was new, it used MERCON fluid which was produced under a Ford license. So your dip stick still says MERCON. Some years ago, however, Ford put out a technical bulletin upudate that now calls for MERCON V in your tranny. You can still use MERCON, however, it is not recommended because the quality control that the Ford license used to ensure is no longer in place.
Your owners manual also calls for MERCON and probably even has a warning about using anything else. That makes it hard to be sure that your auto parts store is giving you the correct information.
Old Apr 16, 2012 | 10:26 AM
c125bob's Avatar
c125bob
Welcome to FTE ! Like Jim said, you are in a different kind of forum, the best !
Old Apr 16, 2012 | 11:03 AM
PaysonPSD's Avatar
PaysonPSD
TSB 06-14-4 Mercon replaced by Mercon V.
ford country boy
Mar 5, 2012 06:36 PM
redvert
Apr 21, 2010 09:01 PM
hoghunter34
Mar 16, 2009 09:13 AM
deo59
1997 - 2003 F150
Sep 10, 2007 12:05 AM
xman7896
Sep 1, 2003 09:12 PM
